Shortcut for resizing cluster
Hey guys,
Quick question. Does anybody know if a cluster control/indicator/constant has a keyboard shortcut associated to it?
Sometimes it's a hassle to right click and go through the shortcut menu. I want to just quickly make it look pretty Smiley Wink
This question arises from the fact that everytime I change/update a typedef cluster, the constant on the block diagram hides all its label 😞
Not sure if this is expected or if its a bug.
Thanks!
(3,329 Views)
Try making it a strict typedef, then the looks will be applied also. If you still want the possibility to change items afterwards, you can change it back to a normal typedef afterwards.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,287 Views)
The block diagram representation of typedef'd clusters has been an issue for many years.
(commonly referred to as 'typedef explosion')
I had made this suggestion many years ago:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-Block-Diagram-design-for-typedefs/idi-p/940093
If this is your problem, please feel free to vote for my idea...
(3,260 Views)
