Shortcut key insert onto wire segment
When using the shortcut for block diagram insertion (ctrl-space, then ctrl-i), the new vi is inserted into the earliest instance of a wire segment, not necessarily the one selected.
This is irritating because I often need the vi inserted after the wire is split (thus inserting onto only one branch of the wire).
(2,538 Views)
And?
I think you should make a suggestion on the LabVIEW idea exchange to have the behaviour modified.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,534 Views)
