Shortcut menu will not show up when I move the folder with the exe to another diretory.
I have several front panel objects that have an associated shortcut menu. When I create an exe the and right click on the FP control, then the correct shortcut menu shows up. If I move the directory to another folder local or on the network, the shortcut menu no longer shows up and only the default menu appears. What is going on? I have been through almost every option?
(2,402 Views)
See if this message thread applies to you. waveform chart shortcut menu problems
(2,393 Views)
