Shortcut search - how to influence terminal selection during object replacement?
It is possible to influence the input terminal used when an object is inserted into a wire. For example, LabVIEW help says under the heading "inserting, objects on block diagram" the following: "Right-click the pixel of white space directly above the wire or right-click the wire itself to connect the wires to the most appropriate terminals at the bottom of the object. Right-click the pixel of white space directly below the wire to connect the wires to the most appropriate terminals at the top of the object."
I would like to know if there is some analogous way to influence terminal selection when existing wired objects are replaced on the block diagram?
For example, if a N
EGATE node is replaced with a MULTIPLY node, is there a way to force the selection of which of the two input terminals on the MULTIPLY node are chosen to be connected to the existing incoming wire?
(2,417 Views)
Hello Warren,
No such feature exists for LabVIEW but it is definitely a feature that could be considered for upcoming versions.
You can submit product requests by clicking the "Contact NI" link at the bottom of this page and the choosing to submit feedback.
Matt F
(2,417 Views)
