Shortcuts in installer page getting removed automatically
Greetings All,
Sometimes I can see that the Shortcuts that I have added in the "Shortcuts" page of Installer build specification in LabVIEW getting removed automatically. Can you help me to understand why this happens and how to avoid this.
Thanks in Advance,
Sree.
(2,898 Views)
You've probably been messing around with your executable build. The shortcut will disappear if the executable that it is trying to place is missing.
You haven't given much information, so we can only speculate. If the above doesn't help, then try to pin-point when the actual shortcut goes away. It's not just disappearing randomly, there's something that you're doing that may cause it.
Cheers
(2,840 Views)
