Should I delete all other versions of a library I decide to use?
I have decide to use NI Modbus Library version 1.1.5.39. I have a few other Modbus libraries downloaded so I was wondering if these libraries will in any way interfere with the Library I plan on using.
Thank you.
(3,083 Views)
The other libraries should not cause any problem unless you start to copy/overwrite between the folders I think 🙂 But your project tree should give the explicit info about what library is used...
(3,040 Views)
They will not interfere.
(3,029 Views)
