Is this a digital interface? What kind of rates are required? NI makes the 653X - High-Speed 32-bit Digital Pattern I/I and Handshaking board. There's also the 650X series. These are static digital I/O with handshaking. After you get more details on the tape drive interface, you might want to contact NI directly to discuss your requirements. As far as LabVIEW versus Measurment Studio, if you use NI hardware, the same functions are available in both packages so it comes down to what you prefer. If you're an experienced LabVIEW programmer, there's no reason to switch. If you're an experienced C/C++/VB programmer, go with Measurement Studio. Imho, inexperienced programmers have a shorter learning curve with LabVIEW.
