Should i use timestamp or cluster?
Hi All,
I am analysing data that has a very small delta t - 4ns and the corresponding graphs are quite short. In the example that i have attached i have generated some random data and i am selecting some of the data. I want to over lay the selected data on the original data so that you can see what you've selected. Currently i am using a cluster to define the delta t and the start point for the graph. I have tried to use the waveform data type but as you will see it doesn't show up very well (i have told the graph to use the timestamp info - if i don't then the selected data doesn't appear at the right place on the graph). You can tell the x axis to not auto scale but it doesn't show the time, just 0.000 - is that the lower limit for timestamp?
Is it good programming practice to use the cluster data time as in the example?
Regards, Phil.
(2,845 Views)
Hi Phil,
what you should do is right click on the graph, select properties. In the second tab (Format and Precision) you can specifiy the details about the display of the ax.  I think you should use relative time with more digits OR use a custom formatting (advanced editing mode) for instance %<%S%10u>t
Ton
My LabVIEW Ideas
(2,837 Views)
Thanks for that Ton,
I suspected that that might be the case. Is is bad practice to use the cluster route?
Phil
(2,837 Views)
  the cluster method is the way you do the plot to the graph, so it's definitely NOT a bad thing so that you have the correct timestamp and dt information.
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(2,809 Views)
