Should "Reload for Each Call" unload after one call?
The subject line says it all, plus I asked the question here:  http://forums.ni.com/ni/board/message?board.id=170&thread.id=190669
I would like to use "Call Setup..." -> "Reload for Each Call" as an convenient way to optimize memory in my big application; however, LV isn't letting go of the dynamically called VIs.  Try running the attached examples with Profiler running and you'll see that only the only way to get the desired result is with "test LV7 dynamic call.vi".
Is there a way to coax the easy "Call Setup..." method into working?
(2,866 Views)
Travis,
I ran all 3 of your VI's with the dynamic call to your 4th, but I added a for loop to them, so I could read data a little more easily form the profiler. I will attach a screenshot to see if you got similar results, but I changed the loop interations, and the memory was exactly the sam, only VI time changed.
test LV7 dynamic call: 31.49kB
test reload for each call: 31.30kB
test load with callers : 29.46kB
So, as you can see, the reload for each call DOES use less memory than the LV7 dynamic call, but load with callers uses even less.
I hope this helps you some.
Chris Van Horn
(2,835 Views)
