Should we install NI-RIO on the starter kit for the Network Stream to work.
Should NI-RIO be installed using MAX on the bot for the PC to transfer data to the bot using NEtwork Streams.
(2,314 Views)
Hi Star,
do you talk about a cRIO system when you write "bot"?
If you do so: yes, you need to install NI-RIO before any software on the cRIO will be able to run...
(2,303 Views)
