Show 8 bit binary data on graph
Hello..
I have an 8bit binary numeric control and I want it to be shown on graph so that it would look like a digital bit pattern just like image below.
Please Help..
(5,081 Views)
First, convert binary data to boolean data.
Next, you can use Waveform Graph.
Community: Convert Boolean to Digital Waveform in LabVIEW
https://decibel.ni.com/content/docs/DOC-6070
GCentral
(5,072 Views)
Thanks for the rplay..
But here you are using a  two dimension boolean array.
I want to use the sequence further for the modulation purpose and need the sequence in numeric  form. (i.e. 0101 etc)
I have a numeric (binary representation) control (not array) and want it to be shown on waveform graph. (not digital waveform which uses boolean).
Can you solve this?
(5,058 Views)
Can you solve this?
(5,055 Views)
Try something like the attached draft (LabVIEW 8.2).
  1. convert number to boolean array
  2. convert boolean array to (0,1) array
  3. graph (0,1) array.
(5,028 Views)
