Show Boolean Text partially hidden behind Indicator of Push Button
In LabVIEW 2009, if I change the Show Boolean Text of a Push Button to either "Spd +" or "Spd+" the "+" is obscured by the Push Button Indicator on the Push Button and is not displayed. Increasing the width of the Push Button a bit does not fix this.
How can I get the Push Button the the LabVIEW 2009 Front Panel to display ALL of the Boolean Text without obscuring any of it behind the Push Button Indicator?
(2,465 Views)
Option 1: Just use the positioning tool to move the text.
Option 2: Customize the control using the control editor to set the text location a little to the left.
Option 3: Use a different button.
(2,458 Views)
