Show Label
Is there a way in LabVIEW to select multiple controls or indicators and
then select "Show label" so that all labels appear at the same time?
(2,948 Views)
If you are talking about programmatic, you can use the Defer Panel Updates
property to control when the screen redraws.
It sounds like you want one popup to operate on many controls, and unfortunately,
the LV editor doesn't support that at this time.
Greg McKaskle
(2,948 Views)
You could try something like this...
For each indicator (and control, but see note below on controls) put a transparent button over them that are in a "switch" mechanical action, the user is then pressing these buttons when they click on the indicators/controls (they don't know they are clicking a button since it is transparent) and when they press the "Show Label" button you programatically show the labels for each of the selected ones.
The problem on controls is this, if you put a button on top of the control, you can no longer "control" it since you are controlling the button and not the actual control. To get around this you can have a "Show Label Mode" that when active places these transparent buttons over everything, when the "Show Label Mode" is not activ
e you can move all the transparent button off screen somewhere.
It sounds like a lot of hassle to do this, but we use to use transparent buttons all the time to get things to happen, i.e. "Click on graph to enlarge" calls a subvi with a larger graph.
Let me know if this works or if it isn't worth the "feature".
--Eldon
(2,948 Views)
