Show Last Element of array differs for horizontal and vertical arrays
Jeff-P,
Thank you.  I will add a link to this thread in the Monthly Bugs list also.
The effects are primarily cosmetic and convenience.  I was working on a job where I need to re-arrange or re-organize some data in an array. I had one array configured for a vertical display and another showing a subset configured for horizontal display.  When I needed to look at the last several elements of both arrays to see if the subset had been calculated correctly, I noticed the discrepancy.  The data represents surfaces in a 2D simulation.  The arrays are clusters of surface type and cell coordinates.  The algorithm which generates the array does not order the data in connected paths along the surfaces. Another part of the program needs such paths, so I am developing an "organizer" VI.  In the image below a surface is defined as any colored pixel which has an adjacent white pixel. The graph shows the values in the surfaces array.
Starting from the segment at (0,0) in the graph, the next segment in the path is the one at x-axis index 1341 followed by the one at 476.  This particular example has four surfaces.  Being able to manipulate and visualize the data is essential to verifying the algorithm.  By the way (0,0) in the image is at the upper left corner while the graph origin is lower left. That keeps things interesting also.
Lynn
Message 11 of 15
(1,114 Views)
Not that your life shouldn't be interesting.....
Message 12 of 15
(1,109 Views)
Jeff,
Thanks.
Lynn
Message 13 of 15
(1,105 Views)
Just come to us with these annoyances and frustrations.  We are here to helpSmiley Very Happy
Message 14 of 15
(1,085 Views)
The axis will flip automatically if you enter the "other limit" on one of the sides. In this particular case you could enter zero at the upper limit marker (240) and the Y axis will flip, swapping the ends. (or enter 240 at the y marker that is currently zero)
No need to open the properties dialog. 😉 (The flip occurs whenever a zero width range would result otherwise)
Message 15 of 15
(1,074 Views)
