Show children windows
We are the team that doing NI supported spirometer.
1. Is there any example on show children windows?
structure:, startup VI contains 3 button for user to choose which child VI to open, and hide itself if child VI shows up( or show up if child VI closed).
StartUp VI
   Education VI
   Diagnostic VI
   Incentive VI
2. After myDAQ gets data(real time plotting), is it possible to start analysis data (show slide bar)  in same VI?
Trying to use a slide bar with two ticks to select partial of plot.
Could anyone give an example?
Tonghua
Message 1 of 15
(5,167 Views)
On the sub-vi, set Show when called, and use Invoke nodes on the main vi to minimize/reopen that window.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 15
(5,144 Views)
Sorry, we are not allowed to use 3rd party toolkit.
Message 3 of 15
(5,113 Views)
What does that have to do with the original question or the reply?
Message 4 of 15
(5,111 Views)
oh, my problem, I thought the link is solution.
I see, Thanks
Now the problem is how to bring main VI back when sub VI is closed.
Message 5 of 15
(5,105 Views)
Have the parent pass its reference (Class Vi Server Vi Vi) to the child.
Use a P-Node in the Child to write property Frontpanel Windows.Behavior as it opens and closes.
Message 6 of 15
(5,096 Views)
This example could open SubVI and return, but once click open again, it freeze. how to solve this?
https://decibel.ni.com/content/docs/DOC-10832
Message 7 of 15
(5,061 Views)
You are correct.  There a a few problems with that example.
Here it is cleaned up a little.  Ask if there are things that do not make sense.
Message 8 of 15
(5,051 Views)
I downloaded your attachment, but it seems the same as original one, which freeze after try to reopen subVI.
Tell me I am wrong.
Message 9 of 15
(5,044 Views)
Accepted by topic author Tonghua
@Tonghua wrote:
Hi, @JÞB
Tell me I am wrong.
D'Oh Try this instead.
Jordan - could you possibly replace the attachment in my previous post with the correct attachment in this one?  If we can't, the link from the community site will just confuse the bejeebbers out of everyone.  My idiocy shouldn't ruin everyones day- just yours and mineSmiley Very Happy
Spoiler
Must be a Friday URGH! Can't I even spell?  I must be chanelling Ben
Message 10 of 15
(5,040 Views)
