Show data into one table
I create 2 arrays with Build Array block.These are the inputs for 2 Number To Decimal String. After that i wwill show data into 2 tables because each Number To Decimal String has an output.
How can i  put these values into the same table?
Thank you in advice.
(3,680 Views)
Try to do your own homework, and then post your code (just attach the .VI file) if you get stuck.
Bob Schor
(3,664 Views)
You need to combine the arrays.
Qestit Systems
Certified-LabVIEW-Developer
(3,570 Views)
