Show files that are not deleted
Hi everyone! Smiley Happy
I have to find a way to show the files that are not deleted, but my code just shows me the last file that is not deleted...
(True and false are written in red because I use a french version of Labview Smiley Wink)
If someone can help... Thank you in advance for your reply!
Message 1 of 8
(3,117 Views)
You need to build an array in the shift register.  Initialize the shift register to an empty array of paths.  In the TRUE case, you need to use the Build Array function to append the new path to the array.
Message 2 of 8
(3,098 Views)
Thank you for your reply! I didn't think about the Build Array function, it seems to be the solution Smiley Happy, I tried but I can't do it, it doesn't work...
Can you show me please? I'm a beginner with Labview...
Message 3 of 8
(3,082 Views)
Something like this should work.
Message 4 of 8
(3,077 Views)
Accepted by topic author rafale350
Or if you want to fit that code on a postage stamp you can use the contitional tunnel feature introduced in LabVIEW 2012.
Come on Tim, Get with the timesSmiley Very Happy
Message 5 of 8
(3,067 Views)
Wasn't sure if the OP has 2012 and I'm still using 2011 for my projects.  At least I'm certified!Smiley Tongue
Message 6 of 8
(3,061 Views)
Thank you both!
I've tried both of yours solutions, but it display each times the last file that has not been deleted... Smiley Frustrated
Message 7 of 8
(3,041 Views)
False alarm!
It's works perfectly!
Thanks! Smiley Very Happy
Message 8 of 8
(3,037 Views)
