Showing a single complete plot symbol in a plot legend, e.g. for scatter plots
I would like a plot legend to show a single plot symbol for each data set in a scatter plot. It appears that a complete symbol is only seen if the legend is sized to show at least 3 symbols, and only if the line width is not too large. Furthermore, the layout is according to the classic "zig-zag" pattern.
Is there any way to show the first symbol both correctly centered (vertically) in the legend, as well as not cut off? Second, is there any way to disable the "zig-zag" pattern, and thus have all points in a given legend appear on a straight horizontal axis? This is particularly useful for generating publication quality figures.
Thanks, Lyle
Message 1 of 10
(4,914 Views)
I know of no way of changing the little graphic that appears in the legend that depicts the graph. I assume that's what you're referring to:
I suppose a workaround is to draw your own legend using a picture control.
Message Edited by smercurio_fc on 06-11-2008 10:17 AM
Message 2 of 10
(4,894 Views)
Attached is an example (LabVIEW 8.2) of how you could draw your own legend using a picture indicator. Probably not the most efficient method, but it's meant for demonstation.
Message 3 of 10
(4,889 Views)
You are correct that I was referring to the graphic that appears in the legend that depicts the graph. Unfortunately, I still haven't installed 8.2 (if ain't broke, don't fix it...), so I cannot see your demo. But the picture strategy seems plausible (if unfortunate).
Lyle
Message 4 of 10
(4,884 Views)
What version do you have? VIs can be back-saved. Here is a picture of the code:
Message 5 of 10
(4,881 Views)
7.1
Message 6 of 10
(4,877 Views)
Unfortunately, I can't backsave to 8.2, as that requires having 8.0. The figure I posted shows the code, which is pretty simple, and all those functions exist in 7.1 so it would be pretty easy to recreate the VI if you decided to pursue this method.
Message 7 of 10
(4,869 Views)
smercurio's suggestion to use a picture control is the way to go if you REALLY need to change from zig-zag to straight. In fact you can build on that idea by using an invoke node "get image" of an off-screen gragh with its legend showing then pull out the portion that shows the legend. Still using the picture functions over-lay the zig-zag with your straight line version and then update you picture. Of course this means you will have to code up all of the plot property functionality yourself.
Ben
Message 8 of 10
(4,866 Views)
Frankly, all of this hacking (in addition to other "features" with controls etc) to make truly presentation (or publication) quality figures with LV  makes me suspect I am missing some key point (especially given the extraordinary power of LV).
Thus, I find that one can generate figures that are *very* close to professional, yet a few details seem elusive. As but one example, I have never seen a graph in a journal article with a legend that imparts any geometry (such as the "zig-zag") other than a straight line. How can this be considered a "feature"?
Any philosophical/practical observations welcome.
Lyle
Message 9 of 10
(4,858 Views)
The zig-zag pattern has the advantage that it shows you what your plot will look like when toggling the various options (e.g. antialiasing, point styles, fills, etc.)
There are VIs in the picture palettes for creating graphs in picture controls. They include code for creating legends.
___________________
Try to take over the world!
Message 10 of 10
(4,830 Views)
