Shrinking the size of full front panel to fit screen resolution of 1024 pixels / 786 pixels
Hello.
I have designed the application and now I found that the screen resolution required is 1024/786. I have many controls and indicators and very worried that the front panel will lose its look and it is going to be time consuming to adjust for each control and text.
I wonder if it is the way that I could shrink the full size of front panel so it automatically reduces the size of every control and indicator and it fits well in the required resolution. Any ideas?
Thanks for help
Kind Regards
Austin
(5,129 Views)
Accepted by topic author K.Waris
Hi Austin,
Thank you for posting this query, this example give below will detect the monitor resolution and resize your front panel to fit it.
https://forums.ni.com/t5/Archive-TKB/Programmatically-Change-Front-Panel-Size-to-Fill-Your-Monitor/t...
Let me know if this has help at all.
Kind Regards,
John McLaughlin
Academic Account Manager
National Instruments UK & Ireland
(5,110 Views)
This VI is also a good one!
John McLaughlin
(5,105 Views)
Is there an example of how you would do this in LabWindows ???  Thanks.
(4,924 Views)
You are in the wrong forum. Try here instead.
(4,910 Views)
Greetings Guys
http://decibel.ni.com/content/docs/DOC-8643
 Unable to access this link. Can anybody help??
(3,245 Views)
