Signal Express for Dummies
Ladies and Gentlemen,
I'm completely new to Labview Signal Express. I want to complete the following extraordinarily complex task: blinking an LED 🙂
Unfortunately I loose my way either in the documentation, in the help system and in Signal Express as well.
What I have:
- Signal Express and Measurement and Automation Explorer installed on my PC.
- cDAQ-9172 is connected through USB, it seems to work.
- NI9219, NI9205 and NI9403 are connected into the base (cDAQ-9172).
- an LED with serial resistor connected to NI9403's port0,0.
- "Getting Started with LabVIEW Signal Express" document, june 2012. It matches with the SW version. (so-so)
What I can:
- in Measurement and Automation Explorer, I can change the direction and the status of port0,0. This way, the LED is ON and OFF, if I toggle it manually. So, the HW is working.
What I can't:
- I'd like to do this LED to toggle, for exaple by 1Hz, automatically. Whatever I do in Signal Express, it never works.
What I need:
- Has someone so many patience, that he could help me? (Before I take a huge hammer which can solve most of the problems 🙂 )
Thans in advance: JeanTheDummy
(3,661 Views)
Accepted by topic author JeanTheDummy
Hi Jean,
why don't you ask your questions in the SignalExpress forum?
(3,657 Views)
Gerd is right. This board is for LabVIEW - a complete and complex programming language. SignalExpress is an application created with LabVIEW. Not many people here are SignalExpress users. Sort of the difference between boards for c++ and excel.
(3,651 Views)
Hi Gerd,
thank you for the link.
Me, as complete stupid, searched for the Signal Express forum in the Support page. There, I couldn't find it ...
Thans again, I go there!
Bye: JeanTheDummy
(3,644 Views)
