Signal Express not activated with Labview Full Development System Volume License
I'm using a volume license manager to generate license for disconnected machines.  I just upgraded to Labview 2009.  The license files work for labview but are not working for signal express.  I have the Labview full development system which included signal express in the past.  Both labview and signal express work fine on my computer that also has the volume licensing manager software installed.   This computer is connected to the license server.  I need to get signal express activated on my disconnected machines.
(2,857 Views)
LabVIEW Full Development licenses still include Signal Express. Are you saying that whenever you are connected to the server you can run Signal Express just fine, but whenever you create a disconnected license Signal Express is not able to launch? Can you verify that you are, in fact, checking a license out from the server whenever you are connected to the network?
If you still have trouble I would recommend calling NI support so we could get more informatioin (such as your license file, contract ID, etc).
(2,828 Views)
