Signal Generation through pt by pt Signal
I am acquiring signal through serial port, to analyze the signal, i am using pt bt pt signal analysis.
In order to work on it, i used sine wave pt pt signal generation. But remained un successful in generating sine wave through it.
Kindly guide me how could i generate sine wave using pt by pt.
(4,788 Views)
Hi Intelligent,
did you follow your nickname and did something intelligent? Reading the context help would be intelligent! You know some nicknames force comments like mine... 🙂
I made up something like this
check.pngafter reading the help and it gives me a sine wave...
(4,785 Views)
Hi Intelligent,
it's not a good idea to start asking by using PNs, I will ignore them in the future!
You wrote:
I already read the help and tried to solve the issue but after not receiving the satisfied results, i posted on the group. As its written in the help that the frequency is in Hz, but the value you have selected for the frequency is 0.01. So its un understandable, also the dependentence of time factor.
- What are "unsatisfying results"?
- Yes, the frequency is given in Hz and I chose 0.01Hz for sake of showing an example...
- "Dependence of time factor" is explained in the context help. Did you really read the help? Or do you have problems to understand the simple math formula provided in the help? All the parameters of SineWavePtByPt are used in that formula...
(4,759 Views)
how rude
(4,676 Views)
Hi Alejo,
My comments weren't meant to be rude, just some irony (or sarcasm) came into play...
Getwonder used to have the nick "intelligent", maybe this explains them a little bit more!
(4,663 Views)
