Signal Generator by Duration function Exercise
Hey, someone maybe knows how I can do this exercise?
Using the Signal Generator by Duration function (multiple use of the function)
generate the following waveform:
y(t) = 10 sin ( ωt) + 10/3 sin ( 3ωt) + 10/5 sin ( 5ωt)
for t from 0 to 2π, where ω = 2π / T, and T is the period of the first harmonic.
Present the signal generated in the form of samples graphically on the XY object Graph. The X axis represents time - find the vector X values ​​based on the following data: number of samples 512 (one period of the first harmonic), sampling rate 25.6 kHz.
example of program:
I tried to make it this way, but I don't think it works correctly
(2,585 Views)
The waveform looks good to me, what is the question again?
Santhosh
Soliton Technologies
(2,573 Views)
Hi michal,
unfortunately you forgot to attach your VI! (We cannot debug/edit/run images with LabVIEW…)
Your image does not fit to your formula:
  • you don't add any sinewaves,
  • you don't have a range of 0…2pi,
  • there are no scaling factors of 10, 10/3, 10/5
Mind to share your code after adapting to your requirements?
(2,549 Views)
