Signal Interference
Hi all,
In Labview I successfully hooked up two pulse monitoring systems to the Labview software. The problem I am having now is that the signals seem to interfere with one another. When you toggle with one of the photo resistors the other photoresitor gives the same graphical readout and vice versa. Any help?
(2,755 Views)
They are probably two high impedance signal sources.  Google the phrase "ghosting".
You could try to separate the channels, putting a dummy channel in between where the analog input is directly tied to ground.  That will allows the charge on the analog to digital circuitry to drain before it tries to read the next channel.
(2,747 Views)
