Signal clipping using PXI-4461 Audio card
We are using a PXI-4461 Audio card. We need to measure a sinusoidal signal that can be to up to 35 Vpeak. Now, we made sure to set the Gain to -20 dB, and set the max range to be +- 42.4V, following data sheet recommendations. However, for some reason, the signal is clipped at +- 10V, just like if the Gain was set to 0dB. We pretty much tried all channel properties without any success.
Any help would be greatly appreciated.
Regards
Alex
(2,327 Views)
Sorry I don't have a solution for you, but a few questions to help tease out the cause of the problem...
Why is AI.max/min etc. set to 15 & -15?
Have you tried configuring a task in MAX with a custom scale and running the measurement on the task in MAX?
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
(2,300 Views)
