Signal conditioning
Hello members,
Let me get this straight and simple. I'm using a cDAQ 9172 and i need to tune the voltage little by little to the maximum of 24V. I found a module NI 9263 (analog output) which can only accept +/-10V. How can the signal be conditioned so that i can be entered into Labview?Is there any module to condition the signal? or can it be done with DAQmx? The same goes to visualising signals (max=24V). How can they can be visualised?
Thanks in advanced!
Dhirah
(3,229 Views)
Hi Dhirah,
you can use external signal conditioning like this http://sine.ni.com/nips/cds/view/p/lang/de/nid/3162.
Mike
Message Edited by MikeS81 on 04-25-2008 07:43 AM
(3,205 Views)
ok continue here
(3,193 Views)
