Signal express log import
Dear group,
Can Signal express load tmds files created from wav recordings? I gave it a try but the file import didn't work for me. I browserd through the examples which worked fine. I tried converting the files to tdms via Diadem, but still no luck with imports. Any tips are appreciated, Thank you.
(3,098 Views)
Start by comparing the header information on the example waves to that of the waves you are using. Maybe the problem is with the application used to create your wave files compared to what the importer expects.
(3,070 Views)
Hi monotone,
Can you give me more information about the TDMS file? Where was it generated? Do you have LabVIEW also?
If you have DIAdem questions you can post questions on the DIAdem discussion forum.
Ima
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
(3,050 Views)
