Signal processing
Hello everyone,
      I  am using veristand to do the HiL simulation, and I give the RT target 1k Hz speed.
My card is PXI-6733, and I want to use the AO channel to simulate a sine signal of 10k Hz.
I do not know how to make it. Can someone help me?
(2,548 Views)
Yes, we can "help you to help yourself".
  1. Open whatever version of LabVIEW (you failed to tell us this) you have.
  2. Click on "Help".
  3. Click on "Find Examples".
  4. Find an appropriate example and study it.
  5. Now write some code.
  6. Test your code.
  7. If it doesn't work, post your code, tell us the problem, provide enough information that we could duplicate it (if we had the hardware).
Bob Schor
(2,525 Views)
OK,Thank you! I use LabVIEW2014, and I will try to write the code.
For Labview RT,with the high speed timed loop, I think it maybe possible to output sine signal.
But I think if the Veristand target can just work with 1k Hz,meaning the target will give a value per millisecond, is it possible for a card to output sine signal for 10k Hz(0.1 millisecond)?
I am not sure。
(2,507 Views)
