Signal scaling with cRIO without MAX?
Using e.g. DAQmx and MAX it was possible to use different scaling and calibration options in MAX. Because the Project Explorer is used instead i can't seem to find any plug n' play solutions when using my cRIO and the onboard FPGA. Is it possible to do something similar in the project explorer as i MAX or should I just start multiplying my way there?
Regards
Soeren
(2,782 Views)
Hi Soeren,
The best way to implement a scale is probably using the Scaling and Mapping express VI in LabVIEW. It has the same basic functionality as a scale in MAX.
Peter Porsman | Applications Engineer | National Instruments
(2,771 Views)
