Signal to Frame CAN - "extended?" not set
I am using conversion of an XNET signal into the CAN frame data format and I realized, that even the signal is part of the XNET frame with extended (29bit) ID format, the "extended?" indicator of output frame cluster remains false. Can somebody explain why? and how to assure the convertor sets the extended attribute according the XNET frame properties?
BTW, I have LV and XNET of version 21 32bit
(1,189 Views)
No issue on my side. I am using LabVIEW 2023 and NI-XNET 2023 Q2
https://tmesystems.net/
(1,178 Views)
