Signal to noise ratio
Hello Everyone, I hope everyone is fine and enjoying good health.
Attached image shows multiple maximum and minimum points of a chopper modulated signal, in order to find the signal to noise ratio can I
use the following formula to get signal to noise ratio
X = (Mean (Max Points) - Mean (Min Points)) / Mean (Min Points)
S/N = 10 * log * Square(X)
Does the Mean of Min points represents the noise of the signal ?
(1,634 Views)
Hi Yum,
When the minimum points are also part of your signal (as it seems) then they don't represent noise…
(1,628 Views)
How can i find the noise voltage if the minimum points do not represent it ?
(1,622 Views)
Hi Yum,
you may subtract the expected signal from your measured signal. The difference will be the noise…
(1,618 Views)
Since you have a periodic signal, I would do it in the frequency domain.
You should see the peaks at n x f_0 and the noise floor.
Greetings from Germany
Henrik
LV since v3.1
(1,580 Views)
