09-23-2005 01:15 PM
09-23-2005 03:51 PM
09-23-2005 04:29 PM
09-26-2005 08:38 AM
09-26-2005 02:49 PM
Good afternoon dclampp,
Thanks for contacting National Instruments with your issue, we'll try our best to get your issue resolved as quickly and efficiently as possible.
Which version of SignalExpress are you running? You can check by going to Measurement and Automation Explorer and expanding the Software tab and checking the version column of the Attributes window. Also is it an evaluation copy?
I just downloaded your project and had no issues modifying the attributes and properties and navigating between tabs and windows. I'm running SignalExpress 1.1.
It sounds like you may have a corrupted install of SignalExpress. It's suggested that all of your drivers be installed first (i.e. NI-Scope, NI-DAQmx etc), then the actual hardware and then SignalExpress. Please try repairing or uninstalling/reinstalling SignalExpress when you get the chance to see if this might resolve your issue.
Please let me know the results of this and let me know if you have any further questions.
Sincerely,
Minh Tran
Applications Engineering
09-26-2005 03:29 PM
09-26-2005 05:01 PM
09-27-2005 12:32 PM
Thanks for the reply dclampp,
There appears to definitely be a correlation between the amount of video resources required and the performance of your system.
There is a knowledge base which talks about this:
http://digital.ni.com/public.nsf/websearch/BB919BECF3BF81D98625708200546766?OpenDocument
Have you run any other programs besides SignalExpress to see if this specific to that program or some general performance issue with the 8196? Do you have the 8196RT, if so if you're running the RTX OS then it's possible a background RT program is using up resources as well.
The 8196 ships with 512 MBs ram but can handle as much as 2 GBs, so it's well within what SignalExpress is using, however it is suspicious.
I cannot see why the 8196 would have any more trouble using a flat panel screen as opposed to a standard CRT screen for equivalent resolutions, but I will definitely ask around about this issue.
Sincerely,
Minh Tran
Applications Enginering
