Signifigant Figures
I am new to LabVIEW programming and I need to know if there is any way to
convert a number to a certain amount of signifigant figures.
(2,813 Views)
I am having to assume you are talking about floating point (ie DBL)
indicators and or controls.
The default for LabVIEW is 2 digits of precision when you create a
control / indicator. If you want to display more digits then right click
on the control / indicator and select "Format & Precision". In the dialog
box you can select the number of digits to display. You may need to resize
the control / indicator to see all of them. As far as calculations are
concerned
LabVIEW uses ALL of the digits, but will only display the number you select.
If this was not the question ask again with more details.
Kevin Kent
(2,813 Views)
