Silent Licensing with NILicensingCmd.exe
I have a LabVIEW executable/installer (LabVIEW 2019 SP1, 64-bit) that is being deployed to multiple windows 10 machines. I had initially hoped that by using the runtime engine packaged in the installer there would be no licensing requirement but it seems NI-IMAQdx needs a valid license even when used in a runtime environment.
I have been attempting to use the following command to do license this package silently over the command line but have had no luck. I have been following: https://zone.ni.com/reference/en-XX/help/371136K-01/nilm/html/automating/ and https://www.ni.com/documentation/en/ni-license-manager/latest/manual/automate-activation/.
NILicensingCmd.exe /silent /activate /type package /name <package name> /version <version> /serialnumber <serialnumber>
where <package name> is NIIMAQ1394_1394_PKG, <version> is 14.0000 and <serialnumber> is my institutional serial number
The package name and version were obtained from "C:\ProgramData\National Instruments\License Manager\Licenses", where there is a single file "NIIMAQ1394_1394_PKG_140000.lic"
After enabling logging (NILicensingCmd.exe /enablelogging 1) I see an exception int the resulting Licensing.log "Operation is not valid due to the current state of the object".
I have also tried nilmutil.exe with no luck, and with admin elevation using both cmd and powershell. I have no issues using this serial number for manual activation.
When I manually check the state of the license in Ni License Manager it shows NI-IMAQdx as being in activation mode with no local licenses.
Also, is it possible to check the state of the license using the command line?
(1,852 Views)
I'd contact NI.  It was my understanding the last time I checked (maybe 5 years ago) that for a Project that involved IMAQdx to be deployed to another computer, a Run-Time License for IMAQdx had to be purchased and installed on the Target machine.  We always did this "manually" where needed.
Bob Schor
(1,803 Views)
