08-17-2021 08:44 AM
I'm trying to setup Labview 2021 to deploy out silently to multiple computers. I've installed it on a computer and run the command 'nipkg.exe download --all-deps --destination-dir="C:\LVFeeds" ni-labview-2021-core-en'. This has copied all the relevant feeds to a folder I've called 'LVFeeds' on the C drive. I've copied this folder off to a network share where I also have a copy of the NI Package Manager v21.
On a clean computer, I have a script to install the NI Package Manger, copy the LVFeeds folder to the local computer and then run a script to install the feeds. The output from the feeds part is below. For a number of the feeds it seems to recognise that they are in the folder in the first part but then seems to be redownloading them to then install them when I already have them already 'imported' them in the first part of the output. I'm confused as to why it might be doing this. Can anyone see anything obvious with the output below or do you need more info?
C:\LVFeeds>"C:\Program Files\National Instruments\NI Package Manager\nipkg.exe" feed-create "C:\LVFeeds" "C:\LVFeeds"
eula-ms-silverlight-5.0_19.5.0.49152-0+f0_windows_all.nipkg
eula-ms-silverlight-privacy-201907_19.5.0.49152-0+f0_windows_all.nipkg
eula-ni-standard.nipkg
ni-activex-container_17.1.2.49152-0+f0_windows_all.nipkg
ni-assistant-framework-custom-ui-tool_21.0.0.49152-0+f0_windows_x64.nipkg
ni-assistant-framework-labview-2018-support_21.0.0.49152-0+f0_windows_x64.nipkg
ni-assistant-framework-labview-2018-x86-support_21.0.0.49152-0+f0_windows_x64.nipkg
ni-assistant-framework-labview-2019-support_21.0.0.49152-0+f0_windows_x64.nipkg
ni-assistant-framework-labview-2019-x86-support_21.0.0.49152-0+f0_windows_x64.nipkg
ni-assistant-framework-labview-2020-support_21.0.0.49152-0+f0_windows_x64.nipkg
ni-assistant-framework-labview-2020-x86-support_21.0.0.49152-0+f0_windows_x64.nipkg
ni-assistant-framework-labview-2021-codegen-support_21.0.0.49152-0+f0_windows_x64.nipkg
ni-assistant-framework-labview-2021-support_21.0.0.49152-0+f0_windows_x64.nipkg
ni-assistant-framework-labview-2021-x86-support_21.0.0.49152-0+f0_windows_x64.nipkg
ni-assistant-framework-ui-assemblies_21.0.0.49152-0+f0_windows_x64.nipkg
ni-assistant-framework-x86_21.0.0.49152-0+f0_windows_x64.nipkg
ni-assistant-framework_21.0.0.49152-0+f0_windows_x64.nipkg
ni-auth_21.0.0.49152-0+f0_windows_x64.nipkg
ni-ceip-x86_21.0.0.49152-0+f0_windows_x64.nipkg
ni-ceip_21.0.0.49152-0+f0_windows_x64.nipkg
ni-codesignapi_21.0.0.49152-0+f0_windows_x64.nipkg
ni-curl_21.0.0.49152-0+f0_windows_x64.nipkg
ni-cvi-2020-reflector_20.0.0.49152-0+f0_windows_all.nipkg
ni-cvi-activex_20.0.0.49152-0+f0_windows_all.nipkg
ni-cvi-analysis_20.0.0.49152-0+f0_windows_all.nipkg
ni-cvi-codegen_20.0.0.49152-0+f0_windows_all.nipkg
ni-cvi-datasocket_20.0.0.49152-0+f0_windows_all.nipkg
ni-cvi-dotnet_20.0.0.49152-0+f0_windows_all.nipkg
ni-cvi-instrsup_20.0.1.49152-0+f0_windows_all.nipkg
ni-cvi-internet_20.0.0.49152-0+f0_windows_all.nipkg
ni-cvi-labview-dll-builder-15.1.0_15.1.1.49152-0+f0_windows_all.nipkg
ni-cvi-network-variable_20.0.0.49152-0+f0_windows_all.nipkg
ni-cvi-networkstreams_20.0.0.49152-0+f0_windows_all.nipkg
ni-cvi-opengl_20.0.0.49152-0+f0_windows_all.nipkg
ni-cvi-openmp_20.0.0.49152-0+f0_windows_all.nipkg
ni-cvi-rte_20.0.1.49153-0+f1_windows_all.nipkg
ni-cvi-runtime-core_20.0.1.49152-0+f0_windows_all.nipkg
ni-cvi-runtime-engine_20.0.1.49154-0+f2_windows_all.nipkg
ni-cvi-runtime-realtime_20.0.0.49152-0+f0_windows_all.nipkg
ni-cvi-tdms_20.0.1.49152-0+f0_windows_all.nipkg
ni-cvi-usi_20.0.0.49152-0+f0_windows_all.nipkg
ni-daqmx-labview-shared-docs_21.0.0.49311-0+f159_windows_x64.nipkg
ni-datafinder-desktop-quit-dc_21.1.0.49153-0+f1_windows_x64.nipkg
ni-dataplugins-python-host_21.1.0.49153-0+f1_windows_all.nipkg
ni-datasocket_21.0.0.49352-0+f200_windows_x64.nipkg
ni-deployment-framework-x86_21.0.0.49487-0+f335_windows_x64.nipkg
ni-deployment-framework_21.0.0.49487-0+f335_windows_x64.nipkg
ni-distributed-system-manager-2021_21.0.0.49488-0+f336_windows_x64.nipkg
ni-error-report-x86_20.1.0.49152-0+f0_windows_all.nipkg
ni-error-reporting-interface_20.1.0.49152-0+f0_windows_all.nipkg
ni-error-report_20.1.0.49152-0+f0_windows_x64.nipkg
ni-euladepot_21.0.0.49153-0+f1_windows_x64.nipkg
ni-example-finder_21.0.0.49488-0+f336_windows_x64.nipkg
ni-help-assistant_2.2.0.49152-0+f0_windows_all.nipkg
ni-iioa-labview-2020-support_20.0.0.49152-0+f0_windows_x64.nipkg
ni-json-map_21.0.0.49152-0+f0_windows_all.nipkg
ni-labview-2019-realtime-nbfifo-x86_19.0.0.49152-0+f0_windows_all.nipkg
ni-labview-2019-runtime-engine-resource_19.1.0.49152-0+f0_windows_all.nipkg
ni-labview-2019-runtime-engine-x86_19.1.4.49152-0+f0_windows_all.nipkg
ni-labview-2020-realtime-nbfifo-x86_20.0.0.49152-0+f0_windows_all.nipkg
ni-labview-2020-runtime-engine-resource_20.1.0.49152-0+f0_windows_all.nipkg
ni-labview-2020-runtime-engine-x86_20.1.0.49152-0+f0_windows_all.nipkg
ni-labview-2021-core-en_21.0.0.49493-0+f341_windows_x64.nipkg
ni-labview-2021-coreother_21.0.0.49485-0+f333_windows_x64.nipkg
ni-labview-2021-deployable-license_21.0.0.49485-0+f333_windows_x64.nipkg
ni-labview-2021-example_21.0.0.49485-0+f333_windows_x64.nipkg
ni-labview-2021-executable_21.0.0.49485-0+f333_windows_x64.nipkg
ni-labview-2021-help-en_21.0.0.49485-0+f333_windows_x64.nipkg
ni-labview-2021-license_21.0.0.49485-0+f333_windows_x64.nipkg
ni-labview-2021-manuals_21.0.0.49485-0+f333_windows_x64.nipkg
ni-labview-2021-realtime-nbfifo-x86_21.0.0.49443-0+f291_windows_x64.nipkg
ni-labview-2021-realtime-nbfifo_21.0.0.49443-0+f291_windows_x64.nipkg
ni-labview-2021-runtime-engine-resource_21.0.0.49488-0+f336_windows_x64.nipkg
ni-labview-2021-runtime-engine-x86_21.0.0.49488-0+f336_windows_x64.nipkg
ni-labview-2021-runtime-engine_21.0.0.49488-0+f336_windows_x64.nipkg
ni-labview-2021-scripting-codegen_21.0.0.49487-0+f335_windows_x64.nipkg
ni-labview-2021-simulation-x64_21.0.0.49485-0+f333_windows_x64.nipkg
ni-labview-2021-vilib_21.0.0.49485-0+f333_windows_x64.nipkg
ni-labview-broker_6.8.3.49152-0+f0_windows_all.nipkg
ni-labview-c-interface_1.0.4.49152-0+f0_windows_all.nipkg
ni-labview-max-xml_19.0.0.49152-0+f0_windows_all.nipkg
ni-labview-system-state-publisher_21.0.0.49487-0+f335_windows_x64.nipkg
ni-labview-vicompare_21.0.0.49488-0+f336_windows_x64.nipkg
ni-labview-vimerge_21.0.0.49488-0+f336_windows_x64.nipkg
ni-license-manager_21.0.0.49380-0+f228_windows_x64.nipkg
ni-logos-labview-2021-support-en_21.0.0.49487-0+f335_windows_x64.nipkg
ni-logos-xt_21.0.0.49350-0+f198_windows_x64.nipkg
ni-logos_21.0.0.49350-0+f198_windows_x64.nipkg
ni-lv-web-server-labview-2019-runtime-engine-x86-support_19.0.0.49152-0+f0_windows_all.nipkg
ni-lv-web-server-labview-2020-runtime-engine-x86-support_20.5.1.49152-0+f0_windows_all.nipkg
ni-lv-web-server-labview-2021-runtime-engine-support_21.0.0.49152-0+f0_windows_x64.nipkg
ni-lv-web-server-labview-2021-runtime-engine-x86-support_21.0.0.49152-0+f0_windows_x64.nipkg
ni-lv-web-server-labview-2021-support_21.0.0.49152-0+f0_windows_x64.nipkg
ni-matlab-interface_21.0.0.49152-0+f0_windows_x64.nipkg
ni-max-remote-provider_21.0.0.49152-0+f0_windows_x64.nipkg
ni-max-rempxi-provider_19.0.0.49152-0+f0_windows_all.nipkg
ni-max-software-provider_20.5.0.49152-0+f0_windows_all.nipkg
ni-max_21.0.0.49152-0+f0_windows_x64.nipkg
ni-mdfsupport_21.0.0.49152-0+f0_windows_x64.nipkg
ni-mdnsresponder_21.0.0.49727-0+f575_windows_x64.nipkg
ni-mesa_17.1.1.49152-0+f0_windows_all.nipkg
ni-metasuite_21.0.0.49152-0+f0_windows_x64.nipkg
ni-metauninstaller_21.0.0.49152-0+f0_windows_x64.nipkg
ni-mkl-2017_17.0.1.49152-0+f0_windows_all.nipkg
ni-mkl-2018_18.0.1.49152-0+f0_windows_all.nipkg
ni-mkl-2020_20.0.0.49152-0+f0_windows_all.nipkg
ni-msdotnet4x_4.6.3.49152-0+f0_windows_all.nipkg
ni-msiproperties_21.0.0.49152-0+f0_windows_x64.nipkg
ni-mssilverlight_5.1.9.49152-0+f0_windows_all.nipkg
ni-mstudio-common-fx40-19.0.0-runtime_19.0.0.49152-0+f0_windows_all.nipkg
ni-mstudio-cw3dgraph_8.7.5.49152-0+f0_windows_all.nipkg
ni-msvcrt-2015_14.1.5.49152-0+f0_windows_all.nipkg
ni-mxs_21.0.0.49152-0+f0_windows_x64.nipkg
ni-networkdiscoverysvc_21.0.0.49152-0+f0_windows_x64.nipkg
ni-opc-support_21.0.0.49350-0+f198_windows_x64.nipkg
ni-opcenum_5.6.3.49152-0+f0_windows_all.nipkg
ni-package-builder-labview-2021-support_21.0.0.49485-0+f333_windows_x64.nipkg
ni-portable-configuration_21.0.0.49152-0+f0_windows_x64.nipkg
ni-python-interface_21.0.0.49152-0+f0_windows_all.nipkg
ni-realtime-error-dialog_21.0.0.49152-0+f0_windows_all.nipkg
ni-registration-wizard_21.0.0.49152-0+f0_windows_x64.nipkg
ni-remote-configuration_21.0.0.49152-0+f0_windows_x64.nipkg
ni-resetniconfig_19.0.0.49152-0+f0_windows_all.nipkg
ni-rpc-21.0.0-realtime-bin_21.0.0.49440-0+f288_windows_x64.nipkg
ni-rpc_21.0.0.49440-0+f288_windows_x64.nipkg
ni-search-labview-2021-support_21.0.0.49485-0+f333_windows_x64.nipkg
ni-search_21.0.0.49485-0+f333_windows_x64.nipkg
ni-securityupdate-kb67l8lcqw-killbits_2.1.0.49152-0+f0_windows_all.nipkg
ni-slcp-x86_21.0.0.49152-0+f0_windows_x64.nipkg
ni-slcp_21.0.0.49152-0+f0_windows_x64.nipkg
ni-ssl-labview-2019-runtime-engine-x86-support_19.0.0.49152-0+f0_windows_all.nipkg
ni-ssl-labview-2020-runtime-engine-x86-support_20.5.0.49152-0+f0_windows_all.nipkg
ni-ssl-labview-2021-runtime-engine-support_21.0.0.49152-0+f0_windows_x64.nipkg
ni-ssl-labview-2021-runtime-engine-x86-support_21.0.0.49152-0+f0_windows_x64.nipkg
ni-ssl-labview-2021-support_21.0.0.49152-0+f0_windows_x64.nipkg
ni-ssl-support_20.5.1.49152-0+f0_windows_all.nipkg
ni-ssp-notifier_20.6.0.49152-0+f0_windows_all.nipkg
ni-svcloc_21.0.0.49152-0+f0_windows_x64.nipkg
ni-sysapi-webservice_21.0.0.49153-0+f1_windows_x64.nipkg
ni-sysapi-wif_20.0.0.49152-0+f0_windows_all.nipkg
ni-sysapi_21.0.0.49153-0+f1_windows_x64.nipkg
ni-syscfg-dotnet-runtime_21.0.0.49154-0+f2_windows_x64.nipkg
ni-syscfg-runtime_21.0.0.49154-0+f2_windows_x64.nipkg
ni-system-webserver-appserver_21.0.0.49152-0+f0_windows_x64.nipkg
ni-system-webserver-base_21.0.0.49152-0+f0_windows_x64.nipkg
ni-system-webserver_21.0.0.49152-0+f0_windows_x64.nipkg
ni-systemlogging-utils_20.0.0.49152-0+f0_windows_all.nipkg
ni-targetdiscoverywizard_21.0.0.49152-0+f0_windows_x64.nipkg
ni-tdms_21.0.0.49152-0+f0_windows_all.nipkg
ni-traceengine_20.0.0.49152-0+f0_windows_all.nipkg
ni-update-service_21.0.0.49243-0+f91_windows_x64.nipkg
ni-usi-core_21.1.0.49154-0+f2_windows_all.nipkg
ni-variable-engine-labview-2021-support-en_21.0.0.49487-0+f335_windows_x64.nipkg
ni-variable-engine_21.0.0.49350-0+f198_windows_x64.nipkg
ni-vipm-helper_21.0.0.49485-0+f333_windows_x64.nipkg
ni-web-pipeline-19.0_19.0.0.49152-0+f0_windows_all.nipkg
ni-web-services-labview-2021-support_21.0.0.49152-0+f0_windows_x64.nipkg
ni-webserver_21.1.0.49152-0+f0_windows_x64.nipkg
ni-wifcoredeps_20.0.0.49152-0+f0_windows_all.nipkg
ni-wif_20.5.1.49152-0+f0_windows_all.nipkg
ni-wsrepl_20.0.0.49152-0+f0_windows_all.nipkg
ni-xerces-delay-load_2.7.10.49152-0+f0_windows_all.nipkg
C:\LVFeeds>"C:\Program Files\National Instruments\NI Package Manager\nipkg.exe" feed-add-pkg "C:\LVFeeds" "C:\LVFeeds\ni-labview-2021-core-en_21.0.0.49493-0+f341_windows_x64.nipkg"
Reading feed metadata inside 'C:\LVFeeds\Packages'
C:\LVFeeds>"C:\Program Files\National Instruments\NI Package Manager\nipkg.exe" feed-add --name=LABVIEW2021 "C:\LVFeeds"
C:\LVFeeds>"C:\Program Files\National Instruments\NI Package Manager\nipkg.exe" update
Updating ni-package-manager-released cache... done.
Updating LABVIEW2021 cache... done.
C:\LVFeeds>"C:\Program Files\National Instruments\NI Package Manager\nipkg.exe" install ni-labview-2021-core-en -y --accept-eulas
The following packages will be installed:
ni-activex-container, ni-assistant-framework,
ni-assistant-framework-custom-ui-tool,
ni-assistant-framework-labview-2018-support,
ni-assistant-framework-labview-2018-x86-support,
ni-assistant-framework-labview-2019-support,
ni-assistant-framework-labview-2019-x86-support,
ni-assistant-framework-labview-2020-support,
ni-assistant-framework-labview-2020-x86-support,
ni-assistant-framework-labview-2021-codegen-support,
ni-assistant-framework-labview-2021-support,
ni-assistant-framework-labview-2021-x86-support,
ni-assistant-framework-ui-assemblies, ni-assistant-framework-x86, ni-auth,
ni-ceip, ni-ceip-x86, ni-codesignapi, ni-curl, ni-cvi-2020-reflector,
ni-cvi-activex, ni-cvi-analysis, ni-cvi-codegen, ni-cvi-datasocket,
ni-cvi-dotnet, ni-cvi-instrsup, ni-cvi-internet,
ni-cvi-labview-dll-builder-15.1.0, ni-cvi-network-variable,
ni-cvi-networkstreams, ni-cvi-opengl, ni-cvi-openmp, ni-cvi-rte,
ni-cvi-runtime-core, ni-cvi-runtime-engine, ni-cvi-runtime-realtime,
ni-cvi-tdms, ni-cvi-usi, ni-daqmx-labview-shared-docs,
ni-datafinder-desktop-quit-dc, ni-dataplugins-python-host, ni-datasocket,
ni-deployment-framework, ni-deployment-framework-x86,
ni-distributed-system-manager-2021, ni-error-report, ni-error-report-x86,
ni-error-reporting-interface, ni-euladepot, ni-example-finder,
ni-help-assistant, ni-iioa-labview-2020-support, ni-json-map,
ni-labview-2019-realtime-nbfifo-x86, ni-labview-2019-runtime-engine-resource,
ni-labview-2019-runtime-engine-x86, ni-labview-2020-realtime-nbfifo-x86,
ni-labview-2020-runtime-engine-resource, ni-labview-2020-runtime-engine-x86,
ni-labview-2021-core-en, ni-labview-2021-coreother,
ni-labview-2021-deployable-license, ni-labview-2021-example,
ni-labview-2021-executable, ni-labview-2021-help-en, ni-labview-2021-license,
ni-labview-2021-manuals, ni-labview-2021-realtime-nbfifo,
ni-labview-2021-realtime-nbfifo-x86, ni-labview-2021-runtime-engine,
ni-labview-2021-runtime-engine-resource, ni-labview-2021-runtime-engine-x86,
ni-labview-2021-scripting-codegen, ni-labview-2021-simulation-x64,
ni-labview-2021-vilib, ni-labview-broker, ni-labview-c-interface,
ni-labview-max-xml, ni-labview-system-state-publisher, ni-labview-vicompare,
ni-labview-vimerge, ni-license-manager, ni-logos,
ni-logos-labview-2021-support-en, ni-logos-xt,
ni-lv-web-server-labview-2019-runtime-engine-x86-support,
ni-lv-web-server-labview-2020-runtime-engine-x86-support,
ni-lv-web-server-labview-2021-runtime-engine-support,
ni-lv-web-server-labview-2021-runtime-engine-x86-support,
ni-lv-web-server-labview-2021-support, ni-matlab-interface, ni-max,
ni-max-remote-provider, ni-max-rempxi-provider, ni-max-software-provider,
ni-mdfsupport, ni-mdnsresponder, ni-mesa, ni-metasuite, ni-metauninstaller,
ni-mkl-2017, ni-mkl-2018, ni-mkl-2020, ni-msdotnet4x, ni-msiproperties,
ni-mssilverlight, ni-mstudio-common-fx40-19.0.0-runtime, ni-mstudio-cw3dgraph,
ni-msvcrt-2015, ni-mxs, ni-networkdiscoverysvc, ni-opc-support, ni-opcenum,
ni-package-builder-labview-2021-support, ni-portable-configuration,
ni-python-interface, ni-realtime-error-dialog, ni-registration-wizard,
ni-remote-configuration, ni-resetniconfig, ni-rpc, ni-rpc-21.0.0-realtime-bin,
ni-search, ni-search-labview-2021-support,
ni-securityupdate-kb67l8lcqw-killbits, ni-slcp, ni-slcp-x86,
ni-ssl-labview-2019-runtime-engine-x86-support,
ni-ssl-labview-2020-runtime-engine-x86-support,
ni-ssl-labview-2021-runtime-engine-support,
ni-ssl-labview-2021-runtime-engine-x86-support, ni-ssl-labview-2021-support,
ni-ssl-support, ni-ssp-notifier, ni-svcloc, ni-sysapi, ni-sysapi-webservice,
ni-sysapi-wif, ni-syscfg-dotnet-runtime, ni-syscfg-runtime,
ni-system-webserver, ni-system-webserver-appserver, ni-system-webserver-base,
ni-systemlogging-utils, ni-targetdiscoverywizard, ni-tdms, ni-traceengine,
ni-update-service, ni-usi-core, ni-variable-engine,
ni-variable-engine-labview-2021-support-en, ni-vipm-helper,
ni-web-pipeline-19.0, ni-web-services-labview-2021-support, ni-webserver,
ni-wif, ni-wifcoredeps, ni-wsrepl, ni-xerces-delay-load
Recommended packages not included (see --include-recommended option):
ni-certificates
Installing 159 package(s); Upgrading 0 package(s); Removing 0 package(s); Downgrading 0 package(s)
Need to get 1.52 GB of archives.
After this operation, 0 bytes of additional disk space will be used.
Downloading ni-securityupdate-kb67l8lcqw-killbits_2.1.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-securityupdate-kb67l8lcqw-killbits: Done
Downloading ni-metauninstaller_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-metauninstaller: Done
Downloading ni-euladepot_21.0.0.49153-0+f1_windows_x64.nipkg: Done
Installing ni-euladepot: Done
Downloading ni-mdfsupport_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-mdfsupport: Done
Downloading ni-labview-2020-runtime-engine-resource_20.1.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-labview-2020-runtime-engine-resource: Done
Downloading ni-labview-2020-realtime-nbfifo-x86_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-labview-2020-realtime-nbfifo-x86: Done
Downloading ni-mkl-2018_18.0.1.49152-0+f0_windows_all.nipkg: Done
Installing ni-mkl-2018: Done
Downloading ni-labview-2019-runtime-engine-resource_19.1.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-labview-2019-runtime-engine-resource: Done
Downloading ni-labview-2019-realtime-nbfifo-x86_19.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-labview-2019-realtime-nbfifo-x86: Done
Downloading ni-labview-2021-runtime-engine-resource_21.0.0.49488-0+f336_windows_x64.nipkg: Done
Installing ni-labview-2021-runtime-engine-resource: Done
Downloading ni-labview-2021-realtime-nbfifo-x86_21.0.0.49443-0+f291_windows_x64.nipkg: Done
Installing ni-labview-2021-realtime-nbfifo-x86: Done
Downloading ni-cvi-openmp_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-cvi-openmp: Done
Downloading ni-assistant-framework-labview-2021-support_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-assistant-framework-labview-2021-support: Done
Downloading ni-assistant-framework-labview-2020-support_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-assistant-framework-labview-2020-support: Done
Downloading ni-assistant-framework-labview-2019-support_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-assistant-framework-labview-2019-support: Done
Downloading ni-assistant-framework-labview-2018-support_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-assistant-framework-labview-2018-support: Done
Downloading ni-assistant-framework-ui-assemblies_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-assistant-framework-ui-assemblies: Done
Downloading ni-rpc-21.0.0-realtime-bin_21.0.0.49440-0+f288_windows_x64.nipkg: Done
Installing ni-rpc-21.0.0-realtime-bin: Done
Downloading ni-logos-xt_21.0.0.49350-0+f198_windows_x64.nipkg: Done
Installing ni-logos-xt: Done
Downloading ni-mkl-2017_17.0.1.49152-0+f0_windows_all.nipkg: Done
Installing ni-mkl-2017: Done
Downloading ni-labview-2021-realtime-nbfifo_21.0.0.49443-0+f291_windows_x64.nipkg: Done
Installing ni-labview-2021-realtime-nbfifo: Done
Downloading ni-error-reporting-interface_20.1.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-error-reporting-interface: Done
Downloading ni-opcenum_5.6.3.49152-0+f0_windows_all.nipkg: Done
Installing ni-opcenum: Done
Downloading ni-msiproperties_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-msiproperties: Done
Downloading ni-tdms_21.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-tdms: Done
Downloading ni-assistant-framework-labview-2021-x86-support_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-assistant-framework-labview-2021-x86-support: Done
Downloading ni-assistant-framework-labview-2020-x86-support_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-assistant-framework-labview-2020-x86-support: Done
Downloading ni-assistant-framework-labview-2019-x86-support_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-assistant-framework-labview-2019-x86-support: Done
Downloading ni-assistant-framework-labview-2018-x86-support_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-assistant-framework-labview-2018-x86-support: Done
Downloading ni-web-pipeline-19.0_19.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-web-pipeline-19.0: Done
Downloading ni-python-interface_21.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-python-interface: Done
Downloading ni-opc-support_21.0.0.49350-0+f198_windows_x64.nipkg: Done
Installing ni-opc-support: Done
Downloading ni-mkl-2020_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-mkl-2020: Done
Downloading ni-labview-max-xml_19.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-labview-max-xml: Done
Downloading ni-labview-c-interface_1.0.4.49152-0+f0_windows_all.nipkg: Done
Installing ni-labview-c-interface: Done
Downloading ni-labview-2021-vilib_21.0.0.49485-0+f333_windows_x64.nipkg: Done
Installing ni-labview-2021-vilib: Done
Downloading ni-labview-2021-simulation-x64_21.0.0.49485-0+f333_windows_x64.nipkg: Done
Installing ni-labview-2021-simulation-x64: Done
Downloading ni-labview-2021-scripting-codegen_21.0.0.49487-0+f335_windows_x64.nipkg: Done
Installing ni-labview-2021-scripting-codegen: Done
Downloading ni-labview-2021-manuals_21.0.0.49485-0+f333_windows_x64.nipkg: Done
Installing ni-labview-2021-manuals: Done
Downloading ni-labview-2021-help-en_21.0.0.49485-0+f333_windows_x64.nipkg: Done
Installing ni-labview-2021-help-en: Done
Downloading ni-labview-2021-executable_21.0.0.49485-0+f333_windows_x64.nipkg: Done
Installing ni-labview-2021-executable: Done
Downloading ni-labview-2021-example_21.0.0.49485-0+f333_windows_x64.nipkg: Done
Installing ni-labview-2021-example: Done
Downloading ni-json-map_21.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-json-map: Done
Downloading ni-iioa-labview-2020-support_20.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-iioa-labview-2020-support: Done
Downloading ni-daqmx-labview-shared-docs_21.0.0.49311-0+f159_windows_x64.nipkg: Done
Installing ni-daqmx-labview-shared-docs: Done
Downloading ni-codesignapi_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-codesignapi: Done
Downloading ni-assistant-framework-labview-2021-codegen-support_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-assistant-framework-labview-2021-codegen-support: Done
Downloading ni-assistant-framework_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-assistant-framework: Done
Downloading ni-cvi-usi_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-cvi-usi: Done
Downloading ni-cvi-runtime-realtime_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-cvi-runtime-realtime: Done
Downloading ni-cvi-runtime-core_20.0.1.49152-0+f0_windows_all.nipkg: Done
Installing ni-cvi-runtime-core: Done
Downloading ni-cvi-opengl_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-cvi-opengl: Done
Downloading ni-cvi-internet_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-cvi-internet: Done
Downloading ni-cvi-instrsup_20.0.1.49152-0+f0_windows_all.nipkg: Done
Installing ni-cvi-instrsup: Done
Downloading ni-mssilverlight_5.1.9.49152-0+f0_windows_all.nipkg: Done
Installing ni-mssilverlight: Done
Downloading ni-msvcrt-2015_14.1.5.49152-0+f0_windows_all.nipkg: Done
Installing ni-msvcrt-2015: Done
Downloading ni-msdotnet4x_4.6.3.49152-0+f0_windows_all.nipkg: Done
Installing ni-msdotnet4x: Done
Downloading ni-cvi-tdms_20.0.1.49152-0+f0_windows_all.nipkg: Done
Installing ni-cvi-tdms: Done
Downloading ni-cvi-analysis_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-cvi-analysis: Done
Downloading ni-wsrepl_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-wsrepl: Done
Downloading ni-auth_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-auth: Done
Downloading ni-cvi-2020-reflector_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-cvi-2020-reflector: Done
Downloading ni-resetniconfig_19.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-resetniconfig: Done
Downloading ni-portable-configuration_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-portable-configuration: Done
Downloading ni-max-rempxi-provider_19.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-max-rempxi-provider: Done
Downloading ni-lv-web-server-labview-2021-support_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-lv-web-server-labview-2021-support: Done
Downloading ni-dataplugins-python-host_21.1.0.49153-0+f1_windows_all.nipkg: Done
Installing ni-dataplugins-python-host: Done
Downloading ni-datafinder-desktop-quit-dc_21.1.0.49153-0+f1_windows_x64.nipkg: Done
Installing ni-datafinder-desktop-quit-dc: Done
Downloading ni-help-assistant_2.2.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-help-assistant: Done
Downloading ni-xerces-delay-load_2.7.10.49152-0+f0_windows_all.nipkg: Done
Installing ni-xerces-delay-load: Done
Downloading ni-rpc_21.0.0.49440-0+f288_windows_x64.nipkg: Done
Installing ni-rpc: Done
Downloading ni-traceengine_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-traceengine: Done
Downloading ni-mstudio-cw3dgraph_8.7.5.49152-0+f0_windows_all.nipkg: Done
Installing ni-mstudio-cw3dgraph: Done
Downloading ni-matlab-interface_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-matlab-interface: Done
Downloading ni-activex-container_17.1.2.49152-0+f0_windows_all.nipkg: Done
Installing ni-activex-container: Done
Downloading ni-mesa_17.1.1.49152-0+f0_windows_all.nipkg: Done
Installing ni-mesa: Done
Downloading ni-ssl-support_20.5.1.49152-0+f0_windows_all.nipkg: Done
Installing ni-ssl-support: Done
Downloading ni-labview-broker_6.8.3.49152-0+f0_windows_all.nipkg: Done
Installing ni-labview-broker: Done
Downloading ni-cvi-codegen_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-cvi-codegen: Done
Downloading ni-systemlogging-utils_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-systemlogging-utils: Done
Downloading ni-svcloc_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-svcloc: Done
Downloading ni-package-builder-labview-2021-support_21.0.0.49485-0+f333_windows_x64.nipkg: Done
Installing ni-package-builder-labview-2021-support: Done
Downloading ni-logos_21.0.0.49350-0+f198_windows_x64.nipkg: Done
Installing ni-logos: Done
Downloading ni-labview-2021-coreother_21.0.0.49485-0+f333_windows_x64.nipkg: Done
Installing ni-labview-2021-coreother: Done
Downloading ni-slcp-x86_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-slcp-x86: Done
Downloading ni-error-report-x86_20.1.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-error-report-x86: Done
Downloading ni-metasuite_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-metasuite: Done
Downloading ni-mstudio-common-fx40-19.0.0-runtime_19.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-mstudio-common-fx40-19.0.0-runtime: Done
Downloading ni-search_21.0.0.49485-0+f333_windows_x64.nipkg: Done
Installing ni-search: Done
Downloading ni-license-manager_21.0.0.49380-0+f228_windows_x64.nipkg: Done
Installing ni-license-manager: Done
Downloading ni-assistant-framework-custom-ui-tool_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-assistant-framework-custom-ui-tool: Done
Downloading ni-slcp_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-slcp: Done
Downloading ni-error-report_20.1.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-error-report: Done
Downloading ni-cvi-dotnet_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-cvi-dotnet: Done
Downloading ni-usi-core_21.1.0.49154-0+f2_windows_all.nipkg: Done
Installing ni-usi-core: Done
Downloading ni-max-software-provider_20.5.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-max-software-provider: Done
Downloading ni-mxs_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-mxs: Done
Downloading ni-web-services-labview-2021-support_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-web-services-labview-2021-support: Done
Downloading ni-cvi-activex_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-cvi-activex: Done
Downloading ni-cvi-labview-dll-builder-15.1.0_15.1.1.49152-0+f0_windows_all.nipkg: Done
Installing ni-cvi-labview-dll-builder-15.1.0: Done
Downloading ni-ssl-labview-2020-runtime-engine-x86-support_20.5.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-ssl-labview-2020-runtime-engine-x86-support: Done
Downloading ni-ssl-labview-2019-runtime-engine-x86-support_19.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-ssl-labview-2019-runtime-engine-x86-support: Done
Downloading ni-ssl-labview-2021-runtime-engine-x86-support_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-ssl-labview-2021-runtime-engine-x86-support: Done
Downloading ni-ssl-labview-2021-runtime-engine-support_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-ssl-labview-2021-runtime-engine-support: Done
Downloading ni-system-webserver-base_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-system-webserver-base: Done
Downloading ni-ssl-labview-2021-support_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-ssl-labview-2021-support: Done
Downloading ni-curl_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-curl: Done
Downloading ni-mdnsresponder_21.0.0.49727-0+f575_windows_x64.nipkg: Done
Installing ni-mdnsresponder: Done
Downloading ni-labview-system-state-publisher_21.0.0.49487-0+f335_windows_x64.nipkg: Done
Installing ni-labview-system-state-publisher: Done
Downloading ni-deployment-framework_21.0.0.49487-0+f335_windows_x64.nipkg: Done
Installing ni-deployment-framework: Done
Downloading ni-deployment-framework-x86_21.0.0.49487-0+f335_windows_x64.nipkg: Done
Installing ni-deployment-framework-x86: Done
Downloading ni-cvi-networkstreams_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-cvi-networkstreams: Done
Downloading ni-cvi-network-variable_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-cvi-network-variable: Done
Downloading ni-logos-labview-2021-support-en_21.0.0.49487-0+f335_windows_x64.nipkg: Done
Installing ni-logos-labview-2021-support-en: Done
Downloading ni-datasocket_21.0.0.49352-0+f200_windows_x64.nipkg: Done
Installing ni-datasocket: Done
Downloading ni-update-service_21.0.0.49243-0+f91_windows_x64.nipkg: Done
Installing ni-update-service: Done
Downloading ni-search-labview-2021-support_21.0.0.49485-0+f333_windows_x64.nipkg: Done
Installing ni-search-labview-2021-support: Done
Downloading ni-ssp-notifier_20.6.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-ssp-notifier: Done
Downloading ni-labview-2021-license_21.0.0.49485-0+f333_windows_x64.nipkg: Done
Installing ni-labview-2021-license: Done
Downloading ni-labview-2021-deployable-license_21.0.0.49485-0+f333_windows_x64.nipkg: Done
Installing ni-labview-2021-deployable-license: Done
Downloading ni-variable-engine_21.0.0.49350-0+f198_windows_x64.nipkg: Done
Installing ni-variable-engine: Done
Downloading ni-cvi-datasocket_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-cvi-datasocket: Done
Downloading ni-sysapi_21.0.0.49153-0+f1_windows_x64.nipkg: Done
Installing ni-sysapi: Done
Downloading ni-lv-web-server-labview-2020-runtime-engine-x86-support_20.5.1.49152-0+f0_windows_all.nipkg: Done
Installing ni-lv-web-server-labview-2020-runtime-engine-x86-support: Done
Downloading ni-lv-web-server-labview-2019-runtime-engine-x86-support_19.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-lv-web-server-labview-2019-runtime-engine-x86-support: Done
Downloading ni-lv-web-server-labview-2021-runtime-engine-x86-support_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-lv-web-server-labview-2021-runtime-engine-x86-support: Done
Downloading ni-lv-web-server-labview-2021-runtime-engine-support_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-lv-web-server-labview-2021-runtime-engine-support: Done
Downloading ni-system-webserver-appserver_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-system-webserver-appserver: Done
Downloading ni-variable-engine-labview-2021-support-en_21.0.0.49487-0+f335_windows_x64.nipkg: Done
Installing ni-variable-engine-labview-2021-support-en: Done
Downloading ni-networkdiscoverysvc_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-networkdiscoverysvc: Done
Downloading ni-remote-configuration_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-remote-configuration: Done
Downloading ni-registration-wizard_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-registration-wizard: Done
Downloading ni-labview-2020-runtime-engine-x86_20.1.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-labview-2020-runtime-engine-x86: Done
Downloading ni-labview-2019-runtime-engine-x86_19.1.4.49152-0+f0_windows_all.nipkg: Done
Installing ni-labview-2019-runtime-engine-x86: Done
Downloading ni-labview-2021-runtime-engine-x86_21.0.0.49488-0+f336_windows_x64.nipkg: Done
Installing ni-labview-2021-runtime-engine-x86: Done
Downloading ni-labview-2021-runtime-engine_21.0.0.49488-0+f336_windows_x64.nipkg: Done
Installing ni-labview-2021-runtime-engine: Done
Downloading ni-system-webserver_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-system-webserver: Done
Downloading ni-syscfg-runtime_21.0.0.49154-0+f2_windows_x64.nipkg: Done
Installing ni-syscfg-runtime: Done
Downloading ni-cvi-rte_20.0.1.49153-0+f1_windows_all.nipkg: Done
Installing ni-cvi-rte: Done
Downloading ni-realtime-error-dialog_21.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-realtime-error-dialog: Done
Downloading ni-distributed-system-manager-2021_21.0.0.49488-0+f336_windows_x64.nipkg: Done
Installing ni-distributed-system-manager-2021: Done
Downloading ni-labview-vimerge_21.0.0.49488-0+f336_windows_x64.nipkg: Done
Installing ni-labview-vimerge: Done
Downloading ni-labview-vicompare_21.0.0.49488-0+f336_windows_x64.nipkg: Done
Installing ni-labview-vicompare: Done
Downloading ni-sysapi-webservice_21.0.0.49153-0+f1_windows_x64.nipkg: Done
Installing ni-sysapi-webservice: Done
Downloading ni-targetdiscoverywizard_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-targetdiscoverywizard: Done
Downloading ni-syscfg-dotnet-runtime_21.0.0.49154-0+f2_windows_x64.nipkg: Done
Installing ni-syscfg-dotnet-runtime: Done
Downloading ni-example-finder_21.0.0.49488-0+f336_windows_x64.nipkg: Done
Installing ni-example-finder: Done
Downloading ni-cvi-runtime-engine_20.0.1.49154-0+f2_windows_all.nipkg: Done
Installing ni-cvi-runtime-engine: Done
Downloading ni-sysapi-wif_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-sysapi-wif: Done
Downloading ni-max-remote-provider_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-max-remote-provider: Done
Downloading ni-ceip-x86_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-ceip-x86: Done
Downloading ni-ceip_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-ceip: Done
Downloading ni-wifcoredeps_20.0.0.49152-0+f0_windows_all.nipkg: Done
Installing ni-wifcoredeps: Done
Downloading ni-webserver_21.1.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-webserver: Done
Downloading ni-vipm-helper_21.0.0.49485-0+f333_windows_x64.nipkg: Done
Installing ni-vipm-helper: Done
Downloading ni-wif_20.5.1.49152-0+f0_windows_all.nipkg: Done
Installing ni-wif: Done
Downloading ni-max_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-max: Done
Downloading ni-assistant-framework-x86_21.0.0.49152-0+f0_windows_x64.nipkg: Done
Installing ni-assistant-framework-x86: Done
Downloading ni-labview-2021-core-en_21.0.0.49493-0+f341_windows_x64.nipkg: Done
Installing ni-labview-2021-core-en: Done
Error -125071: A system reboot is needed to complete the transaction.
C:\LVFeeds>"C:\Program Files (x86)\National Instruments\Shared\License Manager\NILicensingCmd.exe" /addservers *server name and port here*
Server *server name and port here* added to server list.
C:\LVFeeds>"C:\Program Files (x86)\National Instruments\Shared\License Manager\bin\nilmUtil.exe" -s -family "LabVIEW_ADE_190000" -serialnumber *serial number here*
