Silver button text not centered
The boolean text centering in the 'Silver' buttons seems broken to me.  Add a blank silver button, then go Properties>Show Boolean Text>Lock Text in Center.  The text moves down a bit and if you OK it, it never seems to move back.  It's not quite L/R centered either.  My fix is to never check that box... Smiley Sad
(2,930 Views)
Hello Beck45,
You are right, this is not a normal behavior, I will be creating a Corrective Action Request to report this issue. In the meantime the work around solution will be to center the text manually. to disable the Lock Text in Center option just right click the button and select Release Text.
Warm Regards
Mart G
National Instruments Corp.
(2,889 Views)
Ok thanks, and in fact before 'Lock Text' is checked, the text seems to stay centered automatically.  So that's even easier.  It's when you want to release then lock again, that it doesn't work.
(2,887 Views)
