Silver numeric controls
I noticed a small bug while converting some front panels to silver style in LV 2014.
If you replace a numeric control of another style, which has display increment/decrement buttons turned off, with a silver numeric control then the silver control appears with the buttons missing but the thicker boarder where they would be in place. If you cycle the increment/decrement buttons on then off the thick boarder vanishes
e.g replace this modern control (with buttons turned off)
(5,539 Views)
Can you show the image what you see explaining the bug?
(5,526 Views)
I thought I had but lets try again
Replace this modern control with buttons off
With a silver control to get
Cycle buttons on then off to get
(5,522 Views)
Hi Canis,
I am an Application Engineering from the NI team. I was able to reproduce your problem not only with Modern, but Classic and System controls as well. And it is not only with the increment control but some selectable visible items on time stamp control as well.
I wanted to find out additional information from you.
1. Which version of LabVIEW are you running?
2. What operating system are you using?
I appreciate you notifiying us as I think I might need to let the guys at R&D know, but first I will conduct more research and testing on this.
Kind Regards,
National Instruments UK & Ireland
(5,441 Views)
@MariusU wrote:
Hi Canis,
Kind Regards,
1. LabVIEW 2014
2. Windows 7 Professional SP1 (32-bit)
(5,437 Views)
Canis,
Based on what you told me and some experimenting, I filled a Corrective Action Request (CAR). The people at Research and Development will review it and try and implement changes to future software releases. Unfortunately, I cannot guarantee when this would be taken care of as it can be a lengthy process. The request id is 504189, you should be able to look up whether the change has been made in a future LabVIEW version within the changelog.
Thank you for reporting this bug!
Kind Regards,
(5,408 Views)
