Silverlight max 4.7
I found the same problem with MAX. After changing the language on control panel to english, the system is working fine.
Thanks!
Luiz
_____________________ _ _ _ _ _ _
"Together we stand, divided we fall..."
Certified LabVIEW Associate Developer
Message 31 of 36
(1,263 Views)
Hi all,
is there still no solution to the above Silverlight issue? I'm now using version 4.7.4 and still experiencing the same problem.
Yellow
Message 32 of 36
(1,100 Views)
Please try NI System Configuration 1.2. It should contain MAX 4.8 and solve the problem.
Message 33 of 36
(1,087 Views)
Better yet, try System Configuration 5.0 (which includes MAX 5.0) released a few days ago:
http://joule.ni.com/nidu/cds/view/p/id/2613/lang/en
Justin E
National Instruments R&D
Message 34 of 36
(1,082 Views)
Hi all,
just installed MAX 5.0, but no change! Any other idea?
Thanks.
Yellow
Message 35 of 36
(1,069 Views)
Yellow, just to confirm... are you seeing the same two issues as before (as described in this post)? Did upgrading to 5.0 resolve either of those two issues?
Justin E
Message 36 of 36
(1,033 Views)
