Simple Counter to count the number of "True" occurances
Just want to count the number of time a condition is true.Help!
Joe
(3,082 Views)
What exactly is the "condition" that you are trying to count? Is it an input signal, the result of a calculation or what? How fast does the condition change state?
There are a variety of ways of doing what you want depending upon what it is that you're counting.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,082 Views)
On Tue, 5 Aug 2003 20:08:15 -0500 (CDT), mikeporter
>Mike...
I created a vi to parse ascii data from a serial port and am looking
to count the number of occurances of the string. This is probably very
simple but have a brain freeze at the moment
Joe
(3,082 Views)
>Mike...
Joe
(3,082 Views)
One way of doing this would be to put a shift-register on the loop that's reading the port. Initialize the SR with a zero and increment the value each time the desired string is received.
Mike...
LabVIEW Champion
(3,082 Views)
Feed your string into a while loop that stops when a "match pattern" function returns an empty "matched string" (where the "regular expresion" recieve the string you want to count).
THe Match match pattern "offset" input should be fed from a shift register that is initialized to 0 and updated from the "offset past match" output.
The final iteration value should be the number of occurance of the sub-string.
Ben
(3,082 Views)
