Simple DAQ adcquisition questions
Hello Guys,
I am finishing my DAQ LabView module and i have some questions.
I am using waveforms to save the data. My module only has 8 inputs and my board has 16 outputs. I will use a switch but i want that this switch also changes the name of the data. Example:
In first screen appears the time and the value and the prompt "y". Am i able to change that to what i tant?
Second question: Can i delete the miliseconds etc... so annoying and not going to use. Probably DAQ during hours but only getting data like each 1 minute.
Third question (second image): There we have a 1 input schematich. Will be rough to have 8 like that to the computer? Will i lose my data? Will be better to create a For i=1 to 100000000000 and saving each 10 minutes?
4th question: Am i able to manage my panel through my Android / Ios device?
Appreciate the help.
(2,658 Views)
Post your code.  See the section "Attachments" at the bottom?  Push "Choose File", and then find the VI (not a PNG, but the actual VI) and select it.  If you have multiple VIs to attach, compress the folder that contains them all and attach the resulting .ZIP file.
Bob Schor
(2,606 Views)
