Simple Daq Assistant to db issue
Hi
I am trying to write basic DAQ program which:
   - Add or stop channel any time without turning off other channels (Button 0 and 1)
   - pick recording sample rate from 1s- 1hr  (constant array)
   - each recording will have jobn that will be inserted to database, so it can be retrieve later.
but I have below problem (keep in mind i have not touch LabVIEW for long time):
1. the sampling rate is not accurate it is skipping channels (it seems is not live) is this due that database inserting delay
2. Also after couple minute I get hardware can not keep up with this increase buffer.
Can you also give me suggestion on what is proper way of doing such task.
thank you
Message 1 of 1
(1,122 Views)
