Simple Delay 20S Timer
Hello, I am very new here. Want to create a very simple program. Press a button-> start a 20 s Timer-> turn on a LED. Can anyone tell me , how to do that ?
Thanks in advance .
~Repon
(3,738 Views)
Repon,
That is a very simple program.  Have you tried anything? What worked or did not work with what you tried? Have you had any training or have you worked through tthe Getting Started with LabVIEW tutorials on line?
Lynn
(3,728 Views)
So what should happen after 20s. Did you check the function elapsed timer it is what you might be looking for.
(3,723 Views)
My Question is , which timer function should i use for this purpose ?
~Repon
(3,707 Views)
Accepted by topic author Repon
Did you read the post completely? I gave "ELASPED TIMER" function as suggestion. This will let you to do other task inbetween 20s and at the end it will give boolean high. WAIT ms is there but you will not be able to access the Frontt panel for 20s than.
(3,704 Views)
