Showing results forĀ
Search instead forĀ
Did you mean:Ā
Simple Encryption Using Labview
There is one more LabVIEW library for this. Look at http://vigods.com/toolkits/security/aes.html. It's a native LabVIEW implementation of Advanced Encryption Standard, free and NI certified.
Full disclosure: I'm its author.
Igor Titov, ex-CLA
ex-Labicom.net, ex-CERN, etc.
Message 11 of 30
(6,553 Views)
Cool, I will definately check it our when I get time.
LabVIEW 2012
Message 12 of 30
(6,536 Views)
@String_Theory wrote:
Thank you guys. I will clarify that this is not going to be used to encrypt anything important, but is for learning purposes only. When I stated "what can I do better" I meant it as my programming style in the block diagram rather than the method used for encryption.
Considering that the first post was password protected, this sounds a little bit weird! Smiley Wink
Rolf Kalbermatter  My Blog
Message 13 of 30
(6,517 Views)
I have used your AES256 VIs for some time and they have been working very reliably.   I see that they are no longer available on VIPM or on the vi gods website.  I am rebuilding a machine after a hard disk failure and need to reload them.  Is there a new wbsite or source for these VIs?
Message 14 of 30
(6,211 Views)
I'm planning to make them open-source. In the meantime, yes, you can download my AES256 VIs from here: https://vfpsoft.com/aes/
Igor Titov, ex-CLA
Message 15 of 30
(6,195 Views)
Perfect . . .   Thanks again fo your effort on these.
Message 16 of 30
(6,191 Views)
I've done this! Now it's open-sourced: https://github.com/IgorTitov/LabVIEW-Advanced-Encryption-Standard
Igor Titov, ex-CLA
Message 17 of 30
(6,142 Views)
Hi
I am studying 2nd year ECE.I am doing the same thing for my project.I am beginner in Labview.So  it will be really helpful if you provide me the algorithm.Please provide me the algorithm.
Thank you.
Message 18 of 30
(5,557 Views)
I’m sorry to say this but it sounds very much like homework hustling. Have you read the entire thread or simply just attached a: Send me your cedez please! Message?
There are two posts with accessible libraries in this thread. If it is about the theory behind the algorithm you should look on Wikipedia and other sites!
Message 19 of 30
(5,545 Views)
The simplest form of encryption is to XOR a repeating "key" with your data bit by bit. The longer the key the more secure the data.
Decryption is just  XOR the same key to the encrypted data
Here's an example to demonstrate this.
https://forums.ni.com/t5/LabVIEW/Can-you-give-me-some-suggestions-for-encryption-decryption/m-p/2529...
=== Engineer Ambiguously ===
Message 20 of 30
(5,521 Views)
