Simple PID (LV 5.0.1) to 8.6.1 Conversion Help
Hello! I was searching for simple PID and found the attachment unfortunately, it's made from older version of LV. Can someone please convert it to newer version.
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
(11,174 Views)
If you have 8.6.1 Professional, you should have a PID.vi in the LabVIEW Palette anyway.
The VI you used seems to be from an older PID Toolkit, right?
Christian
(11,154 Views)
Hello KowdTek,
If you already have PID Toolkit in 8.6, you should have PID VI. If you have Control Design and Simulation Module,you can refer to the example as followed
Construct PID in Control Design and Simulation Module
https://forums.ni.com/t5/Example-Code/Construct-PID-in-Control-Design-and-Simulation-Module/ta-p/353...
Andy Chang
(11,130 Views)
Christian & Andy,
Thanks! I was just curious to see how the simple PID was built compare to the one in 8.6.1.
Thanks again!
Message Edited by KowdTek on 08-04-2009 10:36 AM
______________
KowdTek
LabVIEW 2009
(11,123 Views)
dear andy,
the PID VI, i couldn't find it under my 8.6 LabVIEW base development system. is it because of my LabVIEW is just develoment not proffesional? i'm looking to develop a simple PID that can be used as my teaching aid for my Process COntrol subject ... please advice me on this matter ...
thanks in advance
azlan
(10,514 Views)
Hello Azlan,
The PID toolkit is not included with the base development system.  You can see all the features included with the LabVIEW Base Development System by following this link https://www.ni.com/en/shop/labview/select-edition.html.
Matt
(10,500 Views)
See attached files converted to version 7.1 🙂
(10,273 Views)
