Simple Time Chart issue, not so "simple"
Hi
check this one
Message 11 of 16
(1,065 Views)
png file..
Message 12 of 16
(1,060 Views)
I'm going to go back and give your For-loop a try again.    Was working on another issue, and I think I figured-out the issue with that (missing "Auto-Index" tunnel).
My "solution" version is still delaying.....just takes longer to notice it.   I'm doing a test run this afternoon, and it's already 3 minutes behind after 30 minutes.....
Message 13 of 16
(1,039 Views)
attached vi please
Message 14 of 16
(1,020 Views)
Were you able to resolve this or are you still running into issues? If you're still seeing the delay problem, I would also encourage you to post you VI here so others in the thread can take a look.
Jen P.
Applications Engineering
Message 15 of 16
(1,009 Views)
Yes, I'm still running into issues.
The VI is already attached.....?   Last post on page #1   "Chart_formatting_fixed.vi"
What's causing most of my issues are delays in other parts of the VI.    The timeframe isn't always consistent, has the hardware doesn't gather data on a Periodic basis....except when idling.   Everything else is event-driven....which messes-up the chart timing.
Message 16 of 16
(1,002 Views)
