Simple XML - Generation
Hi all,
I would like to generate an XML file as shown in below fig.
I can able to generate all the items except which is marked in red and attached vi for ref. (There is an invoke node called insert XML but I am not able to succeed with that). Please can anyone help to solve this issue.
Thanks in advance..
Silver_Shaper | CLD
(4,330 Views)
You need to treat <Actual Status> as a attribute rather then element, so to create attribute example VI attached.
(4,318 Views)
Hi punnet thanks for you reply.
I want exactly like this <Actual Status="Fail">0</Actual>. How can i do that?
Silver_Shaper | CLD
(4,303 Views)
As noted, "Status" is an attribute of the "Actual" node. Did you look at the VI that was posted?
(4,295 Views)
Accepted by topic author Silver_Shaper
I can't open the posted vi since I'm still uisng LV2009 so this may duplicate what was already posted. As was specified Status is an attribute of the Actual node.
Ben64
(4,292 Views)
Please can anyone help me to combine both xml's together attached vi and solutioned vi. I want exactly same on the asked question format (Img).
I am not familliar on XML's.
Silver_Shaper | CLD
(4,241 Views)
