Simple case structure with local variables VS PC architecture VS Event structure (Time analysis)
Here is the result of time analysis between a simple program to run a stepper motor based on 3 different methods. I see there is no great time optimization between the first two and also there first method seems to be slighlty faster.
I believe ( with the help of this forum and other literature sources) that PC should be much a much better method when processing speed and compiler optimization are concerned. Whereas, the 3rd one based on State machine is nearly 50% faster than the first two.
Why is this ?
What could be the possible reason for this kind of results. Is it because the way I programmed is not good and efficient ?? (attached are all the programs)
1. Case structure with local variables.
2. PRODUCER CONSUMER PROGRAM
3. State machine with Event structure
PS: ( The time analysis of previous post I made where wrong as the motor ran twice, the above times are the right ones.)
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
(2,513 Views)
This attachement contains all program (names mentioned clearly)
Abhilash S Nair
LabView Gear:
(2,495 Views)
