Simple elseif statement
I want to write a simple if-else statement in the Formula node in Labview.
I want to write
if (condition)
execute
else if (condition)
execute
else
execute
end
end
but the "else if" generates error in statement. Is this way of writing not allowed? Can I do it in another way?
I want to avoid using a case structure since I already have 5 cases in one case structure and this if statement is just going to be in one of these.
/grogg
Message 1 of 13
(6,386 Views)
Here is the syntax that I found in the help on if statements. Try looking at the help. Sorry i could not help more
if-statement:
if ( assignment ) statement
if-else-statement:
if-statement else statement
Joe.
"NOTHING IS EVER EASY"
Message 2 of 13
(6,382 Views)
I thought that code in those nodes was based on C...  If my memory serves me correctly, an else if statement is C is "elsif" not "else if"
Message 3 of 13
(6,374 Views)
I have look in the help. I'm sorry but it makes no sense writing
if statement else statement
did they forget to write (assignment). I thought it would be
if (assignment) else (assignment) statement
The help file does not say anything about the syntax for else if but I didn't think it would be a problem. Wrinting one if-statement inside another shouldn't be any diffrent then writing a while loop inside another while loop.
Message 4 of 13
(6,371 Views)
I also thought it was base on C. I have tried elseiff too.
Message 5 of 13
(6,367 Views)
Oops, I think I lied...  I was thinking of Perl...  (too many languages!!)
Message 6 of 13
(6,362 Views)
Forgive me for sounding arrogant or foolish, but don't we use Labview to get away from text coding?  Why even bother with if-else statements in a formula node?  Why not do the whole construct in Labview graphically?  I have never used a formula node and I don't expect to ever use one.  All formulas can be created with Labview numerical functions.  I guess I could see constructing a complex formula of math functions (X=2a^2+4b+c-d) using a formula node, but why would anyone want to use a formula node to perform text based coding like if-else and such?  Use Labview graphics and your troubles are over.
- tbob
Inventor of the WORM Global
Message 7 of 13
(6,345 Views)
That answer was as helpful as when people ask for help with windows and the reply is use Linux. Sorry if I sounded arrogant.
Message 8 of 13
(6,341 Views)
The answer is very simple. The code should be:
if (condition) {
    statement
    }else{ if (condition){
                  statement
               }else{
                        statement
Message 9 of 13
(6,330 Views)
I was just wondering why anyone would use a formula node for if-else.  But if that is your preference, so be it.  I have tried this bit of code in a formula node and it works fine:  (a is the input, x is the output)
if(a==0)
     x=1;
     y=11;
else if(a==1)
      x=2;
      y=12;
else if(a==2)
      x=3;
      y=13;
else
      x=-1;
      y=-1;
I also tried an exact copy of your construct:
if(a==0) {
     x=1;
     y=11;
     } else {if(a==1) {
                    x=2;
                    y=12;
                    } else {
                           x=-1;
                           y=-1;
 It worked fine.
- tbob
Message 10 of 13
(6,324 Views)
