Simple feedback control with labview?
Hi
I am still busy with the control of the modified RC-car.
At the moment I try to control the steering of the car. Now I do have the problem that the servo-motor that adjusts the angle of the front wheels is just to fast.
I am getting the current angle from a potentiometer that I mounted at the front.
When I for example want to turn the wheels to the right about 7 degrees the wheel turns right passes the 7 degrees and ends up maybe at 21 degrees.
Than it turns back to maybe -7 degrees. After that it starts turning right again and so on .....
To solve this problem I was thinking about to use some feedback control. A simple PID controller should work.
So my question. How can I do this? Is there any function that I can use to implement the feedback control? Are ther maybe some useful files in the internet?
Attached the VI that I did so far.  Don't mind that it is not finished. It should just clarify what I am going to do.
Bye Martin
(2,894 Views)
Hi Martin,
There is a example in the Example finder called Simple PID Demo.vi that you perhaps can use.
Best regards
/Karin
(2,875 Views)
