Simple listbox example code
I am looking for sample code that creates a very simple listbox.  I want to create a list of items and then run a VI associated with each item.
Thanks in advance,
Nina
Message 1 of 9
(5,234 Views)
List this?
What do you want demonstrated? Clicking an item? Populating it?
Message 2 of 9
(5,230 Views)
You need to look into enumerated values and type definitions in the LabVIEW examples.
Tim
GHSP
Message 3 of 9
(5,228 Views)
Hi--
I want to create a list of instrument tests.  When the user clicks on the test name, the VI associated with that test should be invoked.
Thanks again for your help--N.
Message 4 of 9
(5,220 Views)
@Nina S wrote:
Hi--
Heres an updated one.
But now youre getting into event structures and arrays. Not so simple for a beginner (not saying you are a beginner).
Like aeastet said... your best bet is to look into enums.
Message 5 of 9
(5,216 Views)
Quite true 😞  I am a beginner (more or less...)
Message 6 of 9
(5,197 Views)
Everybody has to start somewhere.
Message 7 of 9
(5,195 Views)
Here is a quick example of what I would suggest that you do.
Tim
GHSP
Message 8 of 9
(5,189 Views)
I'm so used to the array... I forget about the RingText property.
I used the array long before I knew about it.
Message 9 of 9
(5,181 Views)
